Re: minimal sanding
Posted by Laszlo on Dec 28, 2006
I was going to do a minimal sanding job on a boat once, but when I actually started sanding it, it was so much easier than I thought it would be that I just went ahead and sanded it smooth.
A lot of that was the result of the equipment - a good random orbital sander connected to a shop vacuum cleaner, comfortable earplugs and eye protection and high quality sandpaper which I changed very frequently. All of which is suggested in the CLC Shop Tips.
So you don't have to sand it smooth, but settling for some drips & runs may not save you as much labor as you think. Have fun either way.
In Response to: minimal sanding by Q,A, Jaqer on Dec 27, 2006
- Down with runs by Jim E on Dec 28, 2006
- Re: Down with runs by Laszlo on Dec 29, 2006
