Re: 3 rudders 3 foils
Posted by Jim E on Dec 29, 2006
I was wondering if the center hull has enough volume in the bow? There may be moments, particularly when downspeed gybing in waves, when the center hull gets to support most of the weight, just as the rig is pushing hard...
It looks like you've drawn the amas level with the center hull, rather than higher, which should lessen this risk.
In Response to: 3 rudders 3 foils by Brian Cunningham on Dec 29, 2006
11 days
for Discount Code Savings!
Ranging from $30 - $250
