Re: Blend/feathering glas
Posted by George K on Jan 6, 2007
Sanding into the weave won't cause cloudiness. It doesn't hurt to sand a bit into the edge of the top layer of glass to feather it in. Just try to keep the feathered edge straight as it will be slightly visible in the right light at the right angle. The water trick Mac mentioned is helpful, also.
George K
In Response to: Re: Blend/feathering glas by Mike on Jan 5, 2007
