Re: reglassing hull botto
Posted by Dave Houser on Jan 9, 2007
Yes. Use a heat gun and pliers to remove the epoxy/cloth, much quicker than sanding. You can do it without scorching, scratching or sanding into the wood. Use a small heating pad on the stain for a few days and the stain should fade to 20%, did for me. Scratches into the wood are going to show darker.
In Response to: reglassing hull bottom by Patrick Forrester on Jan 7, 2007
