Re: How wide a paddle slo
Posted by Warren on Jan 10, 2007
I agree with Jim E and think a canoe paddle would be the answer. If you are seated in the main hull you can steer with rudder pedals and when hiked out under sail you could use fiberglass tiller sticks ala Hobie Cat. You might want to consider lashing a hiking board across the two forward akas ala Malibu Outrigger style. Not quite as sexy as the rope netting... look forward to hearing more about your project as you progress.... Warren
In Response to: How wide a paddle slot? by Brian Cunningham on Jan 9, 2007
- Canoe Paddle hiking board by Brian Cunningham on Jan 11, 2007
Re: Canoe Paddle hiking b by Camper on Jan 11, 2007
- Years old stuff by Brian Cunningham on Jan 11, 2007
- Sculling by Jim E on Jan 11, 2007
