Re: Sanding into weave
Posted by Mike on Jan 10, 2007
Thanks guys!
I fear not sanding, nor scraping. I'm one of those wierd people who actually enjoy it. From what I hear, barring which grit to use, is that I am safe from sanding into the weave right now. Down at the bow and stern I thought I had the epoxy on pretty thick, which is what you guys also concluded. Before the advice you guys dispensed, I felt like I was walking in the fog towards the edge of a cliff. I feel much better now. I shall press onward, slowly...I also make long bows, so I know when one gets too eager and removes too much wood, or epoxy in this case, bad things can happen. In the case of bows, they tend to explode. The yak will just sink.....
In Response to: Re: Sanding into weave by Laszlo on Jan 10, 2007
