Re: Bulkhead Fit
Posted by Patrick Forrester on Jan 20, 2007
cauck is not a solution.
fillet yes.
I think 1/2 inch is a little much.
I would check the measurement again. I guess that I would opt to put a wide clamp an squeeze the hull to be closer to the bulkhead.
If you are concerned about storage ( and wasted volume in the cockpit ) I would hesitate to move the bulkhead forward. I moved mine back a little. I am not tall. 5' 8"
In Response to: Re: Bulkhead Fit by John F on Jan 16, 2007
