Re: Retrofit rubrail
Posted by Julian on Jan 21, 2007
Mac:
What is the thickness and width of the CLC rub-rail strip? Question about the "rub strip" for the keel under bow and stern. Will that little coverage by the material actually do anything? Would it be better to just add a thick layer of epoxy to the entire bottom? I am thinking, unless you are always landing on a flat sandy beach, the entire bottom is subjected to scratches by rocks, pebbles and sometimes cement.
In Response to: Re: Retrofit rubrail by Mac on Jan 21, 2007
- Re: Retrofit rubrail by Mac on Jan 22, 2007
