Re: Sanding into weave
Posted by LeeG on Jan 22, 2007
you'll have to sand into the weave of the overlapped glass in order fair it in. It'll be obvious.
A shop vac with long hose so the vac can be placed outside will extend the life of the sanding discs and remove dust from the surface to make it easier to see how the sanding is going.
I haven't used scrapers but I'd go with the other folks experience here, fairing down bumps with a scraper makes sense like using a plane makes sense. If you used a sander to round over everything you'd have clouds of dust everywhere.
In Response to: Sanding into weave by Mike on Jan 10, 2007
- Re: Sanding into weave by Mike on Jan 22, 2007
Re: Sanding into weave by Kim on Jan 22, 2007
- Re: Sanding into weave by George K on Jan 22, 2007
- Re: Sanding into weave by Kim on Jan 22, 2007
