Re: Sanding into weave
Posted by George K on Jan 22, 2007
Kim,
Keep in mind heating the epoxy will definitely shorten the pot life. You better be prepared to work fast! Or mix small batches. You'll also have more problems with runs. The viscosity of epoxy at 80 degrees should be fine anyway. I keep my shop between 75 and 80 and have never had a problem.
Then there's guys like Mac in Montreal who would give anything for that 80 degree shop!
George K
In Response to: Re: Sanding into weave by Kim on Jan 22, 2007
- Re: Sanding into weave by Mike on Jan 22, 2007
- Re: Sanding into weave by George K on Jan 22, 2007
- Re: Sanding into weave by Kim on Jan 22, 2007
