grit needed to apply epox
Posted by Patrick Forrester on Jan 27, 2007
I have removed the glass from the bottom of my wr18. I have a smoot thrasition from raw wood to the glass I did not remove.
I am going to overlap the glass. I need to sand some of the existing glass ( 2 years cured ) so the glass overlap will adhire.
What is the minumum grit I can use for this purpose. I prefer to not use a course grit so the final sand is easier and less intrusive.
- 100 grit should be enough by Charlie Jones on Jan 28, 2007
