Re: Brush Cleaner
Posted by cyrus on Jan 28, 2007
Hi, I was told by someone (or maybe I read it somewhere, I can't really recall) just to let it soak for 10 min. and then rinse it off.
I used to let it soak, but then I found I had to spend time rinsing it and drying it thoroughly so I could use it. If you soak, clean and dry right after you use it, it is ready for the next time.
cyrus
In Response to: Re: Brush Cleaner by Chris J. on Jan 27, 2007
