Re: coaming conundrum
Posted by Jim E on Feb 19, 2007
Assuming you've completed the interior filleting and glassing at this point, moving the rear bulkhead would count as major surgery. If it's within a couple of inches of it's design position, I'd leave it alone, and allow enough of an overhang that you can clamp the coaming on. (1/2" should do it)
Moving the deck beam is much easier. Take out the screws and carefully saw through the glue joins. You're going to have to shorten it a bit any way to move it forwards.
In Response to: Re: coaming conundrum by OOPS on Feb 19, 2007
12 days
for Discount Code Savings!
Ranging from $30 - $250
