Re: Coloring Epoxy
Posted by CLC on Feb 19, 2007
I've not heard of much success in tinting epoxy. Solvent-based tints for epoxy exist, but you have to mix so much into the epoxy to actually change the color that the epoxy becomes thick as syrup. And thick epoxy is impossible to 'glass or coat with.
I think you need to stain the wood before you apply epoxy if you want to change the color of the wood. Using a reddish varnish like Cetol works a little bit but isn't especially attractive.
More on staining....
In Response to: Coloring Epoxy by Randy Powell on Feb 18, 2007
- Re: Coloring Epoxy by mark dehnart on Feb 23, 2007
Re: Coloring Epoxy by LeeG on Feb 23, 2007
- Re: Coloring Epoxy by Randy Powell on Feb 24, 2007
