Re: Chesapeake 17
Posted by Jim E on Feb 25, 2007
Varnish might not hide the weave, but epoxy will. You could put on a thin coat once you've got it all nicely faired. then smooth that and start on the varnish
The best way to protect the bolt holes is known as drill-fill-drill. THe link below is to the shop tip.
In Response to: Chesapeake 17 by Jon B. on Feb 25, 2007
