Re: Arma coating
Posted by J. Schott on Feb 26, 2007
Your right, it shouldn't add that much. I had the entire bottom covered in mind when you mentioned Rhino liner. Sorry, I jumped to the wrong conclusion. As far as wiping down before application, use the recomended thinner to wipe down between coats.-Joey
In Response to: Arma coating by Julian on Feb 24, 2007
