Re: Staining the deck
Posted by mark dehnart on Mar 7, 2007
Mornin';
....you WANT to stain the epoxy after you glass the hull. You don't want to wet the glass with stained epoxy. Another choice is painting the hull. I'm currently building one with "DoorSkins". I'm plannin' on staining the wood and coloring the epoxy. But I did have a reason for plannin' it that way. ;) Good Luck
In Response to: Re: Staining the deck by cyrus on Mar 7, 2007
12 days
for Discount Code Savings!
Ranging from $30 - $250
