Re: coaming process
Posted by Jon B. on Mar 8, 2007
I'm working on a 17 and I don't know if the coaming is the same, but what about this approach? Finish sand the hull around the coaming area. Install the spacers. Sand the outside edge of the spacers w/ a Dremel tool. Install small fillet along outside edge. Install top coaming piece and finish sand inside edge. Clean up any epoxy ooze on underside of coaming. Seal and varnish.
In Response to: coaming process by Tom S on Mar 8, 2007
