Re: Primer/paint
Posted by CLC on Mar 10, 2007
The epoxy we ship with Chester Yawls (and all kits) isn't the "blushing" epoxy that frightens Interlux so much. We use the Interlux Pre-Kote on all of our painted boats, including the Chester Yawl in the showroom.
You just need to make sure that the epoxy has been sanded with 120-grit to a uniform gray-white surface before you roll on the primer.
In Response to: Primer/paint by James on Mar 10, 2007
