Re: Frayed ends?
Posted by Garland on Mar 13, 2007
I press a piece of maybe 6 mil plastic sheet on top of the edge and that holds it down nicely.
You can really achieve a high glass/resin ratio putting plastic sheet over the wetted glass and using a squee-gee to squeeze the resin out. It really is vacuum bagging w/o the pump. Also gives you a real smooth surface.
In Response to: Re: Frayed ends? by Mike on Mar 13, 2007
