Re: hull paint questions
Posted by J. Schott on Jun 24, 2007
Yup, I paint in the evening when it is cooler. That is also why I paint 1 panel at a time. Much easier to keep a wet edge working that way. Tipping is what takes the most time and you have a limited window to get the bubbles out before the paint begins to stiffen up. The hotter it is the smaller the area I paint at a time. Penetrol also helps tremendously, it helps the paint to flow.-Joey
In Response to: Re: hull paint questions by John J on Jun 24, 2007
13 days
for Discount Code Savings!
Ranging from $30 - $250
