Re: SW17 - shear to deck
Posted by Jon T on Jul 2, 2007
On the final install the hatches are cut so you can push from the inside, except at the ends where you can't reach. That is where I used dowels. I also put toothpicks between my bulkheads and the sides to let the sides out on the first fit up. That may be what you need to do
You can also get the wire from Lowes, in the area with picture hanging stuff.
Jon T
In Response to: Re: SW17 - shear to deck by DaveG on Jul 2, 2007
