Re: Painting Hull Stripe
Posted by Chris J. on Jul 9, 2007
Thanks John...I was hoping to hear from you. I had not thought of tapering the line but I will try it..I'll taper it up to the underside of the rub rails from maybe 18" back...I'll use the deck nails as a reference. If it turns out half as well as your work I'll be happy. I found some fine line masking tape at a local auto body supplier so I think I'm ready. Hope to post some pictures of the finished product by the weekend.
Thanks again.
Chris
In Response to: Re: Painting Hull Stripe by John Beck on Jul 9, 2007
