Re: I use electrical tape
Posted by Robert N Pruden on Jul 10, 2007
"I thought of another reason why it is good to remove the tape after each coat of paint; if there were any leaks under the tape you can clean it up before the paint dries. "
That is a good point but if you use a craft knife then you can carefully scrape off any runs. I used the craft knife method because I'm kinda lazy when it comes to having to redo the tapes.
Robert N Pruden
In Response to: Re: I use electrical tape by John Beck on Jul 10, 2007
- Re: I use electrical tape by Chris J. on Jul 11, 2007
