Help! Varnish on Paint
Posted by Larry on Aug 28, 2007
Hello All,
Sory to take up all the forum space, but there has been a new issue! Taking everyone�s good advice, I decided to forget about the minor bug tracks on the deck varnish and be done with it. However, upon peeling off the tape (varnished deck, painted hull) I found that (gasp!) varnish had snuck underneath the tape and onto the nice white paint! This was the 3M Fine Line recommended by and bought from CLC stuff! Assuming I did something wrong, is there any way to remove the varnish without marring up the paint? I know, I should just put the boat in the water, but I just can�t, not without at least trying to clean up some of this mess! Thanks in advance!
Larry
