Re: Help! Varnish on Pain
Posted by Robert N Pruden on Aug 28, 2007
If you try to remove the varnish then you will probably mess up the paint as well. I'd sand it lightly to remove the varnish off the paint and do some touch up work. Use elctrical tape pressed firmly to reapply the paint and varnish. I believe this is your safest bet. Hope this helps!
Robert N Pruden
In Response to: Help! Varnish on Paint by Larry on Aug 28, 2007
