Re: Help! Varnish on Pain
Posted by Dave houser on Aug 28, 2007
Sand and polish per Green Valley Boat Works' website and quoted below: http://www.greenval.com/FAQvarnishing.html "Then, with a hard sanding block and 600 grit or finer wet sanding paper, carefully wet sand the repair, leveling and blending with the surrounding area. Work your way through progressively finer sandpaper, 1000, 1200, and 1500 grit. Then, using a cream polish such as Meguires No.3 and a thick, soft cloth like an old diaper, polish this area. For a really high polish, switch to Meguires No.6 or higher. These materials are available from any autobody repair supplier."
Or my old post on polishing varnish linked below.
Polish My How-To
In Response to: Help! Varnish on Paint by Larry on Aug 28, 2007
