Re: Rate Your Workspace
Posted by Robert N Pruden on Sep 5, 2007
I started cutting the panels from sheets of okhume in my livingroom, which could only just fit the sheets, 12' length max. The panels were glued there then tied with wire there. The wired hull was then moved into the basement of my rental house. That basement looks like it was used as the basement set for the movie "Silence of the Lambs". Down "there" is where I glued and glassed the hull and deck. At least it is a heated working space. I used to build in a rather airy, unheated single car garage which never saw any car that I ever owned parked within its breezy walls. I do have the option of using my mom's well-heated and large garage but that space has been reserved for my Night Heron stripper project.
Robert N Pruden
In Response to: Rate Your Workspace by Tim Clark on Sep 4, 2007
- My space rates a solid 3 by Robert N Pruden on Sep 6, 2007
