Re: sounds normal
Posted by craig on Sep 19, 2007
Try using some stick on felt pads between the frame and the the hull it may just be the seat rubbing. Epoxy against epoxy or varnish sounds a lot like nails on a chalkboard.
In Response to: sounds normal by LeeG on Sep 19, 2007
