Re: Ches 18' build order
Posted by George K on Sep 20, 2007
The main problem I see is winding the hull is done then the fillets and inside glassing on that boat. Then turn it over, snip off the wires, sand and glass. The way you mentioned is more like the West Rivers where the hull is placed upside down on two level horses and the pannels are tabbed with epoxy. Wires are pulled, the tabbing completed, sand and glass. I guess it'd work on a Chessy but I'd wait for others to chime in.
George K
In Response to: Ches 18' build order by Anton on Sep 20, 2007
- Re: Ches 18' build order by Jim E on Sep 20, 2007
