Re: Ches 18' build order
Posted by Jim E on Sep 20, 2007
Another thing to watch for: Some epoxy will leak through to the inside between the 'tacks' when you are glassing the outside, and may create some runs on the inside of the hull. You can catch these by ducking underneath a few times during the first hour or two of curing time, or you could seal the joins first by butting a bead of thickened epoxy into them after taking out the wires and before sanding. Are you able to cover the kayak between work sessions?
In Response to: Re: Ches 18' build order by George K on Sep 20, 2007
