Re: leaky boat
Posted by Emily on Sep 20, 2007
There is some staining in the inside as well. When I was sanding I started to see a bit of the cloth pattern so I took some extra time after sanding and put another coat of epoxy over the whole thing then sanded again with 120 then 220 before painting / varnishing. Overall, I think I had 2-3 coats of epoxy on the whole thing, then that last final coat during the sanding process. The hatch, I think, is an easily fixed issue as I just need to re-epoxy the edges. The rest of the hull, though, is going to be a project!
In Response to: Re: leaky boat by Darryl on Sep 19, 2007
