Re: Ches. 17. How much Ep
Posted by Kyle Lindstrom on Sep 24, 2007
Doug, Just want to be sure on what your saying. Two gallons used on two kayaks so a gallon of epoxy per kayak right. I will do 3" tape on the interior seams. Then cloth in the cockpit and full cloth on the exterior of the hull. I know it might be close on the epoxy (3 qts) so once I get the interior seams done I will do the hull cloth before the cockpit. No cloth on the deck so I will use less epoxy than you. I have been trying to mix the epoxy in small batches so I don't waste any. Thanks for you help!
Kyle
In Response to: Re: Ches. 17. How much Ep by Doug W. on Sep 24, 2007
- Re: Ches. 17. How much Ep by Jim E on Sep 24, 2007
- Re: Ches. 17. How much Ep by Doug W. on Sep 27, 2007
