Re: actually it doesn't
Posted by John Beck on Sep 24, 2007
Larry, You can make your own bondo with the epoxy of your choice and West System Microlight 410. It has the same characteristics of bondo, except it takes longer to cure and it doesn't smell so bad. The color is ivory.
Good luck, John
In Response to: Re: actually it doesn't by Larry Roberts on Sep 23, 2007
