I use at LEAST two
Posted by Charlie Jones on Oct 10, 2007
depending on the color I'm using. I've found that whites and very light colors cover far better than darker ones. Using dark colors, and particualrly the blues and greens ( in my experience) it takes at least three coats and sometimes four to get good coverage.
Brightsides wants to be applied quite thinly or it'll sag and or run which is part of the reason for the needing multiple coats.
As to buffing, I'll have to let some one else answer that part- never tried it since I usually spray finish the boats I build.
In Response to: Re: You really don't by Kyle Lindstrom on Oct 10, 2007
- Re: I use at LEAST two by Kyle Lindstrom on Oct 10, 2007
- Ususally a small amount by Charlie Jones on Oct 10, 2007
- The thinners are by Charlie Jones on Oct 10, 2007
