Re: Strength Test Results
Posted by Camper on Oct 13, 2007
Hope you do find time to do the test to determine which provides the most strength. Here's a design.
Samples are same weight, length, and width. Sample A is plywood, Sample B is plywood epoxied on both sides, Sample C is plywood glassed on both sides.
If the C is less than 100% stronger than A, then the plywood provides most of the strength.
Good luck, though, matching the weights without compromising the outer veneers of Sample A.
In Response to: Re: Strength Test Results by Robert N Pruden on Oct 12, 2007
