Re: Ask MAS?
Posted by Jim E on Oct 16, 2007
I have experienced mild hangover-like symptoms after breathing epoxy fumes, so it's not completely safe. My fix for this is to run a fan, blowing air through the workspace, to disperse the vapors. I find I don't need to wear a mask if I do this. If your workspace is inside the house, and it's cold outside, you might have a problem.
In Response to: Ask MAS? by Doug S on Oct 15, 2007
