Re: MC mast partner quest
Posted by CLC on Dec 6, 2007
The mast partner should be about an eighth-inch wider all the way around than the mast tube. It should feel sloppy in the shop, though under load, on the water, it won't, and you'll appreciate it not getting jammed.
In Response to: MC mast partner question by Mike on Dec 6, 2007
- Re: MC mast partner quest by Mike on Dec 6, 2007
