11. Aligning Mortises and Tenons
CLC Ultralight Dinghy - Mortises and Tenons
Mortises in the bottom panel align with the tenons on the center frame.    You will probably have to rasp the corners of the tenons on the center frame for a good tight fit in the mortises.   Wire stitches pass through the bulkhead and through two holes in the hull panels, to be tightened on the exterior.
« Previous Post     List of Posts     Next Post »
14 days
for Discount Code Savings!
Ranging from $30 - $250
