13-14. Stitching Stringer to Bottom Panel
Stitches are passed through the stringer and the bottom panel, forcing the bottom to take on the correct rocker. You'll need to use pliers to pull these stitches tight.
Tenons on the stringer slot into mortises in the bottom panel for perfect alignment.
