34-35. Tack-Welding the Hull Seams with CA Glue
If you have CA glue, this is a really quick way to tack-weld the hull seams. Just a drop of the CA glue between each stitch, preferably followed by a squirt of accelerant, is all it takes. If you don't have CA glue (available from CLC or from a modeling store), you can use unthickened epoxy dispensed from a disposable syringe.
