Epoxy doesn�t dry fast enough
Hi, people:
I'm glassing a S&G Night Heron here in Santa Fe, Argentina. Temperature is now 12-16° C on night and 20-22° C where sunlight.  I´ve glassed the hull 30 hours ago and epoxy is still soft. The mix was ok I think.
My problem is that I am working on a space without three walls, it has roof a one wall only. Then, if wind blows, the dust will stick to the kayak. I´ ve had luck until now, but I am interested in speed up the drying.
Can I, 30 hours ago, expose the hull to the sun for a while without be affraid of outgassing?. What do your recomend to speed up the drying? I´ ve read the "Epoxy in Cold Weather" in Tips Section. May be a polyetilene tent with lights is my best option?
Some photos in http://cid-fdb625df781f8e56.skydrive.live.com/self.aspx/Tmp
Thanks in advance
Ivan
RE: Epoxy doesn�t dry fast enough
Ivan,
 12-16 is a little cold for the epoxy.  It should cure, but will take longer.  I would see if you can add plastic walls to your building space and put some small heaters in there.  I noticed that in my garage with nighttime temps around 10-12 degrees C, it would take a few days for the epoxy to completely cure up.
Buena suerte con su proyecto!  Este sitio web es un lugar fantastico para recibir respuestas por todas sus preguntas.
Chris
Thank Chris!. It´s good to ear that it isn´t abnormal my drying times. I´ll give a try to the plastics walls or a tend with small heaters.
Best Regards.
Ivan
