I'm sure that I've read the answer here before, but it's currently alluding my search. I'm doing a light fill coat on the interior of my SW17, but the wet-out coat left a few drips with a small bit of pooling in a couple spots. Would you recommend sanding out the drips, etc before the fill-coat or after? I guess my concern would be sanding into the glass if I did it beforehand. Thanks for your help as always.
-Zach
RE: Quick Question re Fill Coats
Thanks Paul. I didn't have anything near bad enough to cause a usage problem - this was just cosmetic. I ended up sanding/scraping the high spots down in the cockpit and then applied a very thin coat of epoxy to seal it up. It seems to have worked well and shouldn't have added too much weight. The boat seems to be coming along well.
» Submitted by PAG - Wed, 6/23/10 » 5:54 PM
You really don't need any fill coatsw inside the boat. The exposed weave gives you a little bit of nonj-skid and the extra eposy is just weight. If you have some drips that might snag something then knock them down with sanding or a scraper. If you are talking about the cockpit then a few coast of varnish will prtect you frm teh sun, otherwise leave it as is.
Paul
