Hi, people. I've fiberglassed my Night Heron's Deck and now I can see a white spot in the stern may be because an excess of squeeging there. Please, can you me give an advice about how can I fix it?. May be a light sanding prior to another coat of epoxy?
You can see some bad photos in
http://cid-fdb625df781f8e56.photos.live.com/self.aspx/Tmp
Thanks in advance
Ivan
From Argentina (and very sad because Futbol)
RE: Excess of squeeging
Uh. I want a bright finish. The rest of my deck is Ok. Are these the only two solutions?
Thanks in advance
Ivan
If you want a bright finish and you don't want the white spot to show in your finish, you have to carefully cut out or sand out the white spot. It is the only way, but it is not difficult if you take your time. Then apply a patch of fiberglass cloth over the sanded area and apply epoxy. Good luck.
Sorry about the Futbol.
Thanks for the advices. Finally, I´ve removed the fiberglass in that area. Now I´m cleaning the area and after that, I´ll apply a new one.
Ivan
» Submitted by Camper - Sun, 7/4/10 » 3:49 PM
I think that it your are correct about the cause--the glass was starved of epoxy. I think that this condition can only be fixed by removing all of the fiberglass and feathering in a patch, or by choosing a painted rather than a bright finish.
I have some patches where this happened. You can see the fibreglass and there is a silvery appearance. I decided to paint the hull.
