Preferred method of finishing fillets
I am doing the finishing work on an Annapolis Wherry and I was just wondering how folks have gone about finishing their fillets. Do you sand them smooth or just leave them with the coarse textured surface. I have them looking neat and even, but they still have that wood flour texture. Will the subsequent brushed-on un-thickened epoxy provide enough smoothing? Thanks in advance for your thoughts.
RE: Preferred method of finishing fillets
If the fillet is going to be glassed I don't do anything to it, just lay the glass on it while the fillet is still wet. Then it becomes a fill-the-weave-problem instead of a smooth-the-fillet problem.
For unglassed fillets I brush on a coat of unthickened epoxy while the fillet is still wet with a chip brush. That leaves a glassy-smooth surface.
» Submitted by Old Yeller - Fri, 7/9/10 » 12:55 AM
A piece of sandpaper wrapped around about a 2" long round wooden dowel is what I use on my fillets. Normally many low spots are left that the sandpaper doesn't reach. If I was chasing perfection I might apply a second thin layer of wood-floured epoxy, but I've never done that. A top coat or two of unthickened epoxy gets them smooth enough for me.
Grant
