How much wet sanding is required between coats of varnish? How do you know when you've sanded "enough?" I've been applying thin coats of Captain's varnish mixed with 10% Penetrol and the coats of varnish are very smooth, even without sanding.
Thank you,
Mark
RE: How much wet sanding?
» Submitted by Laszlo - Wed, 7/21/10 » 12:25 PM
Just enough to smooth down any large bumps, drips, brushmarks, etc. and to take the shine off so that the next coat will adhere.
