I have just sanded the epoxy on my Jimmy Skiff and touched up the spots where the sanding appeared to have penetrated to the fiberglass. Next step is painting. I have decided to go with a finish of matte latex porch paint. Can I prime with Pre-Kote? I notice that Pre-Kote is petroleum-based; this does not sound like something that will mix well with water-based latex paint. On the other hand, I can see the petroleum base being extremely volatile (keep the shipyard well ventilated!), evaporating quickly, and the resulting gunk bonding to both the scored epoxy and the over-paint and making the paint stick more tenaciously. Which is it? Either of the above, or something different fromboth?
Thanks in advance!
1 reply:
RE: Pre-Kote compatibility
» Submitted by twofootartist - Thu, 9/16/10 » 8:40 PM
I thought someone who is a paint expert would answer your question, but it shouldn't go unanswered. My understanding and experience is that you can always use an oil-based primer under latex paint, but not the other way around. -Wes
