Hey where did you guys get those neat "eye" images, like the ones they painted on the bows of Greek galleys?
RE: Line Art
If I were to do it I think I would find someone who could produce the artwork on a computer then take the file to a sign maker and have them cut out vinyl reproductions. That way if I didn't like the way they looked I could easily remove them.
RE: Line Art
» Submitted by SRoytman - Thu, 12/23/10 » 11:37 AM
I didn't get them from anywhere, but I did actually consider putting a pair of eyeballs (Phoenecian, originally, I think) on my Jimmy Skiff, the Metaphor. Decided against, though. Too gimmicky. I figure, the name and maybe a bright red pennant, either CLC's or one I can put together, will be just the right amount of non-serious.
But if I were to do it. I would decide what I wanted the things to look like. I would then choose some key points---inner and outer corners of the eyes certainly, maybe some additional points. Then I would make some kind of jig to mark the points symmetrically on either side of the prow. Maybe a piece of cardboard with a wedge cut out at the same angle as the prow, and inches marked on each side of the wedge. This way I could mark the key points on corresponding places on the two sides. And then paint freehand between key points. Plan on n coats of paint, for some n that will cover the lower color with the upper, and as I am informed it is the idiom on this planet, the name of your father's brother is Robert.
