Hi, Just a quick question regarding the bilge panels on my MC16.5 kit - is it normal to have the little 'bump' at either end? When I first saw them I thought it might have been an error in the laser cutting but the more I look at them I think that they are supposed to be like that - do they fit over the end points of the bottom panel?
I'm not quite at that stage yet - still glueing sheer clamps - but thought I'd ask before I got there.
Steve
p.s. I'm talking about the notch at the bottom end of the panel (not the little spike which I'm yet to sand off).
RE: MC16.5 bilge panels
Thanks John,
Yes it was the little 'detente' that I was referring to.
Cheers
Steve
» Submitted by John, CLC - Sat, 7/12/08 » 11:08 AM
The little sharp thing is where the CNC machine started and left off, and as you stated correctly, that's to be sanded off.
A few years ago we added the "detente" at the end of the bilge panel to indicate, emphatically, where the bottom panel engages the bilge panels. It's helped a lot with assembly.
