varnish wet sand rubbing compound Schooners
I'm just finished painting the hull of my kayak with brightside; came out beautiful and finished putting 6 coats of varnish. Now I've just read that Interlux also recommends not wetsandint and buffing out the varnish; just like their brightside. The brightside is one thing; it flow out great and is on the hull. I'm in denial regarding the varnish. It's hard to imagine that I wouldn't have a better short and long term appearance with the wetsand to 1600 plus grit followed by rubbing compound routine. Has anyone done this with Schooners (gold) product. Any advise?
What varnish can you wet sand and buffer for final finish. I thought you can do this to them all. I've had great results in the past.
thanks in advance
10 replies:
RE: varnish wet sand rubbing compound Schooners
One of the CLC professionals recommended thinning the Schooner varnish with 10% mineral spirits and 10% Pentrol. I did that on my last finish job and I loved the way the varnish applied and as well as the final outcome. It flowed well upon application and the final product looked much better than the unthinnned application of Schooner varnish
I am using the Zspar Captains varnish and the first 2 coats went on too thick for my my preference. After talking to Matt at CLC I thinned it with 10 percent Penetrol and it flows better, still leaving a few brush strokes. I will try the addition of 10 percent mineral spirits on the 4th coat. How many coats are most of you guys using and what are you sanding with between coats? I am thinking of launching tomorrow after my 4th coat(today) and wait until October to get that "perfect" finish and put it away for the winter so it will harden/cure good for next spring. I used Brightside Sea Green for the bottom, it looks OK(great from 5 feet away). I did not thin the Bright side, are any of you guys thinning the Brightside Paint?
Rod
I just finished my Guillemot today. I used the Schooner varnish and it worked great. I never used varnish before and I thought that it was going to be hard to work with.
I used the Schooner varnish straight from the can with out any thiner. I used a foam brush and it flowed great, without any brush marks.
I worked in my basement at 70 deg. and 55% humidity.
I dulled the finish with a Scotch Bright pad between coats. I have three coats on now. In a few weeks, after the varnish has hardend, I will sand it smooth with 400 grit and put one more coat on.
On my Shearwater I wet sanded with 400 grit before the final coat and did the same before I refinished it last winter. I used Schooner Gold thinned with mineral spirits and Penetrol (as per Joey) and this worked fine.
On my wife's boat I used Schooner thinned the same way and did not wet sand. I find that letter a reason to do less work and that's just fine with me.
Your boat is looking great, Lou!
I thinned both the brightside and the schooners gold with 333
The brightside went on suprisingly easy and came out near perfect. Mirror finish, no brush strokes, one small drip and a very small amount of dust, which I would like advice on how to take down.
the varnish went on pretty well, no brush strokes showing but a couple of drips. Unfortunately I decided to use some of the carbon fiber eye straps that added difficulty to varnish around and was were the drips developed. I wished I didn't go with these.. I would of been happier installing eye straps that came with kit.
Thanks Dan
It's a shearwater 17 hybrid. My first attempt with strip and glue.
» Submitted by Curry, Brad - Fri, 7/1/11 » 2:47 PM
fyi
very quick response, as always, from Jay at Interlux
Hi Brad,
